INFO-TECH
Joined: 14 Sep 2006 Posts: 1 Location: Cardiff, United Kingdom Thanked: 0 times
Posted: Thu Sep 14, 2006 6:51 pm Post Subject: CABLE ROUTING WITHIN CEILING JOISTS |
Has anybody else come across this regulation regarding the routing of cables:
pipes notched within nine inch joists, 25mm holes drilled through nine inch joists more or less centre of joists and about 6 inchs diagnolly away from pipe route.
nhbc building officer has refused to issue cert unless 25mm holes are at lease 6inches HORIZONTLY from the pipe runs away.
Now heres the funny bit, building officer claims the 9 inch joists will be under stress from a 25mm hole being drilled close to the pipwework notches.
However, the way around it was to drill new holes approx 3inches away from holes already drilled, and run all cables through these!! MORE HOLES, MORE STRESS!!
Can anyone explain as this has cost me alot of time and money, from what i can see for a very poor reason.
Thanks for any responses. |
plugwash
Joined: 28 Mar 2004 Posts: 6931 Location: United Kingdom Thanked: 16 times
Posted: Thu Sep 14, 2006 6:56 pm Post Subject: |
sounds like just someone interpreting rules too literally and making things worse not better, it happens all the time. Not much you can do about it though. |
Taylortwocities
Joined: 27 Jul 2006 Posts: 4939 Location: Oxfordshire, United Kingdom Thanked: 63 times
fireman22
Joined: 18 Mar 2005 Posts: 605 Location: United Kingdom Thanked: 0 times
Posted: Thu Sep 14, 2006 8:37 pm Post Subject: |
what came first the cable or the pipe (no jokes) |
Taylortwocities
Posted: Thu Sep 14, 2006 8:49 pm Post Subject: |
This is an electrical forum. Therefore its obvious that the cable was first!
Actually you coudnt have drilled the cable holes if the pipes were there first..... not straight holes, anyway. |
fireman22
Posted: Thu Sep 14, 2006 9:27 pm Post Subject: |
my right angled drill could, but if you look the wood is cleaner at the notch than inside the holes, so, electrician beats plumber.
old electrician told me that electricians are the god's of the trades, i always use this quote.  |
Kes
Joined: 31 May 2006 Posts: 391 Location: Worcestershire, United Kingdom Thanked: 0 times
Posted: Fri Sep 15, 2006 7:05 am Post Subject: |
That's not a notch, it's a trench. |
