nielsc
Joined: 22 Sep 2006 Posts: 5 Location: Glasgow, United Kingdom
Posted: Fri Sep 22, 2006 7:46 am |
I need to do a small patch to a roughcast wall.
I have done quite a bit of searching on the web and there has been a lot of advice. I just want to make sure that I am doing the right thing.
The patch should consist of two layers
1) a scratch coat (3 sharp sand: 1 cement + waterproofer)
2) the rough cast coat (4 sharp sand: 1 cement +waterproofer? + 6-10mm chips
Wet the wall and the put on the scratch coat. 10mm thickness maximum. As it gets drier scratch some horizontal lines in it. Let it dry out.
Can I use any kind of 6-10mm chips for the rough cast coat or do they have to be lime chips? What proportion of chips should I use in the mix?
Do I need waterproofer in the roughcast coat?
Wet the scratch coat and put on the roughcast coat.
Does this sound correct? |
Moz
Joined: 19 Jun 2005 Posts: 5141 Location: United Kingdom
Posted: Sun Sep 24, 2006 4:03 pm |
That sounds ok to me ,
yes use lime chips... |
nielsc
Posted: Tue Sep 26, 2006 8:39 am |
Thanks Moz.
I think I will go ahead now.
Will put waterproofer in both coats, better safe than sorry. |
JohnD
Joined: 15 Nov 2005 Posts: 34467 Location: Hampshire, United Kingdom Thanked: 1097 times
Posted: Tue Sep 26, 2006 10:15 am |
If you are doong a patch, I take it a small section in an existing wall? it can be difficult to get a match, but if you sweep under the old wall you will probably find plenty of the stones or chippings that were used before and have fallen off. You might be able to incorporate them in the final layer. |
