Had above condensing combi fitted in June & all worked well in initial test with inbuilt clock. Since then had remote timer fitted, which doesn't seem to start anything - changed for new zero v one & still nothing. Yet all ok on inbuilt timer apart from 1 thing - after some time of heating boiler makes vibrating noise, which stops if you open the hot tap, and shuts down with A07 fault....failure to reignite.
Suspect the spark damaged PCB or recently fixed leak from carpet fitters nail have something to do with it. But why does it work ok on inbuilt timer & HW fine. Pressure is steady at 1.8 bar.
Need a fix b4 my new born comes home in a few days & not getting much joy from spark.
