Joined: 25 Sep 2006 Posts: 6 Location: United Kingdom Thanked: 0 times
Posted: Mon Sep 25, 2006 11:02 pm Post Subject:
removing radiator tail
I\\\'m replacing a broken radiator, and so need to take the \\\"tail\\\" of the valve fitting out of the old radiator to put it into the new one. However, I am having great difficulty unscrewing it, despite having the right allen key. Any ideas? Thanks!
Also, any ideas how to take the old olive off the pipe, as I want to change one of the valves?
Joined: 21 Oct 2004 Posts: 19532 Location: United Kingdom Thanked: 6 times
Posted: Mon Sep 25, 2006 11:38 pm Post Subject:
Re: removing radiator tail
Put the short end of the Allen key in the tail, put the hole at the end of a pair of adjustables over the long end of the key, and apply consistent force until it turns. It may be difficult, but that's life.
Use either olive cutters or an olive puller. For example:
Joined: 22 Nov 2003 Posts: 1761 Location: United Kingdom Thanked: 0 times
Posted: Tue Sep 26, 2006 7:04 am Post Subject:
If you are using the hacksaw method, dont cut all the way through the olive, cut about 80% through, then put a flat bladed screwdriver in the slot and twist. The olive should then split.
Posted: Wed Sep 27, 2006 11:05 am Post Subject:
radiator fittings
Thanks for the help re the radiator tail fitting and olive removal ... the first I've not managed yet, but I've removed an olive.
However, the olive left a mark on the pipe, so it is slightly misshapen, with a slight bulge, which is making it hard to put the new fitting on, because I can't get it over the bulge ... any ideas, anyone?
Joined: 08 Oct 2006 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Sun Oct 08, 2006 7:41 pm Post Subject:
Thanks!
Might sound daft, but try tightening first - just sufficient pressure to "crack" the seized threads. Frequently works with nuts and bolts on cars etc etc
Joined: 28 Apr 2006 Posts: 7 Location: Edinburgh, United Kingdom Thanked: 0 times
Posted: Mon Nov 06, 2006 3:33 pm Post Subject:
Radiator Valve Tail Removal
I have a tool for removing the Tail of radiator valves from the radiator (It is much like a large Allan key).
However recently when helping out my brother I found that the tool did not fit his radiator valve tail. The tool is slightly too small with the result that it just slips inside the tail. Is this a metric / imperial thing or is just simply that there are different sizes?
Any shops / website recommendations for getting my hansd on the right sized tool?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
