DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Bath Mixertap Dribbles
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
icantplumb
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 26, 2006 9:17 pm    Post Subject:
Reply with quote Thanks
Guys my bathroom mixer tap has recently started causing me some problems. First of all my cold water went from good pressure to barely a trickle in a relatively short period of time. I suspected a washer or something broken inside the tap, unable to turn the supply off i simply loosened the valve thing slightly and the water flowed ok again.. within a couple of days the same problem has moved over to my hot tap.
I dont know how to turn the supply to both hot and cold off at the same time so your assistance would be greatly appreciated along with any suggestions as to what may be the cause of the poor pressure... best regards and thanks Mick
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
tincup
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 26, 2006 9:34 pm    Post Subject:
Hi
Sounds like a blockage in the tap body that began in the cold feed.
Turning off hot and cold water will depend on what type of h/w system you have. More info on this please.
Hope this helps
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Wed Sep 27, 2006 5:04 pm    Post Subject:
rat`s skull...........from the cold supply cistern in roof icon_eek.gif have seen one icon_lol.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Mixer Tap - Hot water dribbles 6 320 Mon Feb 12, 2007 10:52 pm
Boiler dribbles water to outside via pipe why? 8 340 Fri Feb 08, 2008 10:31 am
CH works but hot water dribbles 5 360 Mon Nov 27, 2006 9:57 pm
Help with a small Heat Store water heater-dribbles a little 5 260 Sun Jan 11, 2009 11:34 pm
cast iron bath, worth anything dead or alive 2 240 Wed Feb 27, 2008 9:04 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
