Mono Basin Taps - Ceramic Valves Query
23 Jul 2006
Bournemouth
Sorry probably dumb question but just had a mono basin tap with ceramic valves fitted (single spout - two knobs type). Both knobs turn anti-clockwise to turn water on - which of course means that the left knobs turns forward and the right tap backward and that can't be right (certainly my kitchen tap handles both turn forward). Are there left hand and right hand valves (and the manufacturer has therefore fitted two left hand valves) or is there something that can be adjusted in the valve to change direction of on/off?
There are 'paired' ceramic disk modules which turn on in opposite directions, and unpaired ones which all turn on anticlockwise.
Sounds like you're stuck with what you have, although I suppose you COULD try to get a replacement left-handed module to fit....
OTOH - I'm unconvinced that handed taps are in general a good idea. If you have a visitor who has un-handed ones at home, he'll probably rip the top off your hot tap trying to turn it on, or turn it the wrong way later and leave it running by mistake.
I'm told that the general trend is for UK taps to operate one way and US "faucets" to operate the other (whether monobloc and singular design). Although there are many exceptions to that.
It doesn't really make a lot of difference as far as I can see - you soon get used to the one you have, but if you're particularly concerned then you can shop around for ones that do suit your desires. I agree with Croydoncorgi though - sorry Steve86, you're almost certainly stuck with what you have.
