Indesit WD12X broken door lock
30 Sep 2006
Cheshire
Hi, I have a WD12X and I need to remove the door catch as it has broken. I can access the locking unit from above but am unsure how to remove it ready for replacement. 5 Shirts are stuck inside! Any suggestions? :cry:
I'm assuming the door is jammed shut.
Get a thin piece of wire or string, feed it into the door and pull it back to unlock the door. (Hope you get what I'm trying to say here).
Once the door is open you'll be able to ascertain what parts are required to repair
I may be being thick, but I assume the wire is supposed to pass on the left of the catch from top to bottom and then be pulled to the right. Sadly I don't seem to be able to do this. Any suggestions.
If your door handle is on the right, feed the wire from the right side of the door and work it until both ends are at the left side, then pull to the left.
What a star!!! Success and now I can wear a shirt on Monday! Many thanks for your help. :LOL:
My washing machine is Indesit WD84T, the door handle is broken and now the door is jammed shut. Where shall I inside the string? Is it from the front thru the door handle opening, or via machine lid opening from inside?
Problem is I could not figure out where the string or wire should go... help! :cry:
this worked for me also, piece of string held vertically in both hands fed from r to l then pulled to left releases catch mechanism, brilliant, just got to fix broken lock now or teach my missus how to do this......hmmmm...yeah, fix lock! ;)
tip top this worked for me also - good advice. now just need to find and rpelace door lock - any ideas where to source and manual of how to ?
cheers
PS - just bak from hols with two suitcases of washing :evil: :evil: :rolleyes:
i can't get the string from right to left... can some1 could explain me how should i do that???
