DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Flexiale bath fitting....
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
markallen
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 30, 2006 9:51 pm    Post Subject:
Reply with quote Thanks
i was told i could use a flexible fitting for my bath connections,,,a bit like speed fit...however these are white and nylon wrapped.
I have connected one end to the bath taps and the other to a 22mm copper pipe compression fit using the nut and olive which was supplied.Their are no leaks but it just looks like i have just conected pipes to the back of my washing machine.It looks to simple and cowboyish..is this realy a standard type of fitment,it is 1000mm long i was told by 2 B&Q guys that it was suitable for my application,can i expect this flexible pipe to burst when i am on holiday?...
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Sun Oct 01, 2006 1:29 am    Post Subject:
If you have gravity feeds you might not get much water through it. Look in the end - the ones in Wickes are all of 6mm internal diameter.
If you have a combi or unvented HW then they're a risk, check their spec.
Back to top
 Alert Moderators
markallen
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 02, 2006 6:32 pm    Post Subject:
ta chris but without sounding like a **** what is a unvented system..i do not have a combi,and the system is belived to be gravity feed into the taps this i understand i think.as for the flexi pipe it is only 10-15 mm but does not apper to affect the water flow into the bath even though it has been taken off a 22mm copper..I do have a large water tank in the loft and the standard rad header tank..What should i look for if it was to be unvented...
cheers mate....
mark
ps
cant find the tag that came with them....i dont think it said very much what should it say.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Drilling Bath and fitting Legs 2 600 Sun Aug 22, 2004 10:56 pm
Fitting a bath 2 280 Fri Feb 01, 2008 2:20 pm
Stupid bath fitting question 4 420 Mon Feb 26, 2007 3:47 pm
Bath fitting 2 4060 Tue Aug 24, 2004 3:03 pm
Awkward bath tap fitting 3 420 Fri Aug 27, 2004 8:03 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
