Is it possible to re-route a gas fire flue? There is a fan and it terminates directly behind it to outside. Were extending out this way and want to know what our options are. thanks
Depending on how far u need to extend the flue it shouldnt be a prob. Provided its following the same straight path a new flue should be the only outlay.
Only thing is the legend flues are around 500mm long uncut and im unaware of being able to extend this distance. Id phone them for advice - no on back of instruction manual.
Thanks for that will do, the only way i can extend it is either up through the single storey extension roof, or down under the new joists to the outside. Get rid of fire time i think, thanks people
