DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Blanking holes where UPVC window handle used to be ...
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
m13
from United Kingdom
PostPosted: Mon Oct 02, 2006 12:39 pm Reply with quote
We have a room sealed oil boiler and when it was moved the only place it could go involved the flue outside too near to the utility room window. The solution agreed with building control was to seal the window so it could not be opened and allow fumes in the room from the flue.
The agreed method of sealing the window was to lock it shut with the key and then remove the handle and blank over the three holes (two for the screws for the handle, one for the handle mechanism).
This has all worked fine except we can't find a blanking plate of any sort to cover up the holes in white upvc. I don't really want a self-adhesive one as getting it off if the window needed to be maintained (with the boiler switched off) could be tricky.
I've tried a variety of places but nowhere can help with a blanking plate and seem astonished that building control weren't happy with the window simply being locked. However, as all of our window keys are the same, they were concerned that somebody could simply get a key from another window and open up the window and kill themselves with the carbon monoxide and we'd rather be safe than sorry.
Can anybody think of a solution for me?
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Mon Oct 02, 2006 4:38 pm Reply with quote
white insulation tape?
piece of white plastic trimmed to size?
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Thu Oct 05, 2006 12:12 pm Reply with quote
How about keeping the handle as it is, and adding an additional lock to the window - with a unique key. This gets around the 1 key fits all problem, and leaves the window in a state that you can maintain/clean it.
Another option would be to close/lock the window and then remove the handle, fitting a replacement handle with the spindle taken out - preventing the mechanism from being opened.
Back to top
 Alert Moderators
skybluescooby
from United Kingdom
PostPosted: Fri Oct 13, 2006 5:05 pm Reply with quote
Speak to these guys www.the-plastic-surgeon.co.uk They can do an invisible repair on the holes and probably set you back about £50.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Cost for replacing double glazing with blanking panels? 3 120 Tue Jan 11, 2011 8:40 pm
UPVC window dripping through hook holes??! 6 400 Wed Apr 20, 2011 11:15 pm
Drill holes upvc frame 4 160 Fri Mar 16, 2012 9:22 pm
Fill small holes in PVC window 2 100 Sun Aug 05, 2012 1:36 pm
Inst. new curtain rod but too many previous holes in wall! 3 560 Sun Oct 30, 2005 9:42 am
DIYnot
