I wish to change the water main to my property which is in a semi rural area, I wish to change from 15mm soft copper to 25mm plastic. I have dug the whole length of my front garden to a depth reaching the existing 15mm main to the edge of my property and know that the water company main runs four feet outside my property in the grass verge, the problem I have is that there is not a stop cock in this space, the only stop cock is within the property!
My questions are: Are the water board obliged to come and fit one, allowing for me to change my supply up to it, if not how do I go about fitting my new main.
Also I have not dug the on the outside of my property yet and did not know the set up of the tee'ing off from the waterboard main, in other words will I be able to get the benefit of using 25mm or will it have to be reduced down to 15mm in order to connect to their supply leaving a bottleneck!
Any help would be much appreciated,
Best regards, Martin
