DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
floor boards
This topic originated from the How to page called Stopping creaking floorboards
Click here to return to the page called Stopping creaking floorboards.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
john kennedy
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 09, 2004 1:14 pm    Post Subject:
floor boards
Reply with quote Thanks
i have renailed floor boards all over the house and still they creek,having run ins with neighbours.
Council man stated must be the way the structure of the house was built as he could not advise what could be done...all secure but unless it is because of the metal joists as upper flat. I dont know what the solution can be -any ideas
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 7 times
PostPosted: Mon Feb 09, 2004 4:00 pm    Post Subject:
Listern very closely and see where the noise is coming from,is it the floorboards or joists etc.? Might have to lift the floorboard and investigate.If it just the floorboards creaking then put talcum power and brush it in the joints.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Mon Feb 09, 2004 6:10 pm    Post Subject:
pull all the nails out and replace with screws.
nails will work loose, if you put a screw in place of nail they do not work loose, aalso pilot hole is there and you will not hit any pipes or cables, since the nail didn't
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
john kennedy
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 11, 2004 10:57 am    Post Subject:
nail all replaced with screws and no matter were you stand in any room the whole floor creaks.
it must be the joists as no other way we can do anything to rectify
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Wed Feb 11, 2004 1:00 pm    Post Subject:
Do you know where the joists is resting on ? Is the joists in the wall etc ?
Back to top
 Alert Moderators
nsutebufru
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 16, 2004 8:00 pm    Post Subject:
Squeeeky floor boards - help!!!!
I am faced with the same problem. Very squeeky floor boards all over 2 bed rooms - not localised. I have got someone to nail them down - no success. Then someone else tried to screw them down but no change. What can I do now? The house is old, built in 1950's. Should I just replace all the floor boards? What is the cheapest solution as want to sell the house? icon_cry.gif
Back to top
 Alert Moderators
Building Contractor
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 17, 2004 7:47 pm    Post Subject:
This problem can occur if the floor joists have not been installed with sufficient size per span ratio and/or not correctly strutted. Remedy can be very difficult with probable solution in doubling up on some floor joists where access can be achieved
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Wed Mar 17, 2004 8:46 pm    Post Subject:
Does sound like no herringbone was not put in.
Back to top
 Alert Moderators
nsutebufru
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 18, 2004 8:39 pm    Post Subject:
Squeeky floors
Thanks for the replies and useful advice. The house is a livett-cartwright construction. The frame is made of steel stanchion rods and the walls built with concrete slabs. The squeeking became much worse after central heating was installed. What are herringbones? Given the advice about checking out the joists, I am considering getting a builder/joiner to check it out as it seems I need a pro for the job.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Thu Mar 18, 2004 9:12 pm    Post Subject:
Re: Squeeky floors
To make the floor solid and not bouncing.
Gee,these young carpenter got it made, I has to make mine out of timber or I'm now classified as old icon_smile.gif
Back to top
 Alert Moderators
nsutebufru
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 25, 2004 8:00 pm    Post Subject:
icon_confused.gif I have finally decided to replace all the floor boards with fibreboards, which I understand is what is used for most new houses now. Will cost me £500 but hopefully that will be the end of the squeeks!!!
Thanx for the ideas
Back to top
 Alert Moderators
IanDB
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 26, 2004 11:41 am    Post Subject:
Don't bank on it!! If the fibre boards aren't secured properly you'll end up back at square one!!
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Fri Mar 26, 2004 8:55 pm    Post Subject:
Agreed, best to lift the floorboards up and have a look at the joists for movement as you're going to do it anyway.
Back to top
 Alert Moderators
John Dee
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 06, 2004 10:52 am    Post Subject:
AS a matter of interest, if the concrete floor was flat enough, could you glue the boards in to position?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Floor Boards 3 240 Tue Apr 08, 2008 7:08 pm
Tile look laminate boards for floor but the walls as well?! 3 860 Mon Jun 04, 2007 1:18 pm
How to put floor boards back down. 3 260 Thu Apr 10, 2008 11:15 am
New solid pine boards over concrete floor in bathroom? 3 880 Tue Feb 14, 2006 8:54 am
advice please: tongue and groove boards onto chipboard floor 3 780 Fri Jun 02, 2006 7:32 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
