Hotpoint WM62
8 Oct 2006
Lincolnshire
My washing machine recently stopped so as normal when this happens i changed the brushes(they needed doing)however this as not solved the problem,the maching will fill and start its wash but stops when it gets to the rinse and spin cycle,i have tried a new control unit but still no joy,please help my wife is going crazy.
Hi, My guess is the cold water valve or the rinse valve is gone. Disconnect power and check the coils on the valves with a meter.
See "Sticky" note at top.
Regards
Den
That is usually a symptom of worn brushes on this model it will go through the wash cycle ok but when asked to work a little harder in rinse/spin mode the motor stops at this point and the program stops. If you have just changed the brushes recentley and have had the machine functioning ok for a while check the brushes again for premature ware if this is the case a new motor will be required as the armature has distorted or lifted. If it has never fully worked since changing the brushes it would still indicate a fauulty motor and the only thing I can think of is that it may be a build up of carbon on the armature. You can inspect this with one of the brushes out. If it looks burnt/black you can obtain a armature cleaning stick from a white goods supplier. It would be worth a try before the cost of a new motor.
Thanks to :Tockworth and 5Toke5
Did as you sugested only to find that the problem was one of the brushes was sticking back inside its case, this was due to the metal securing tag being pushed down therefore holding the brush back, all is now ok thanks for your help.
