DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Combi boiler: shower pressure too high
This topic originated from the How to page called Planning a shower
Click here to return to the page called Planning a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
apjilly
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 09, 2006 9:45 am    Post Subject:
Reply with quote Thanks
We recently had a Bosch combi bolier installed and a new Mira Discovery shower (because the old Mira wouldn't work without a gravity feed, and the tanks above the shower were taken out with the old boiler).
We tried the shower and it seemed to have a mind of its own (even when no other appliances were in use), adjusting from hot to cold, and from a trickle to full blast. Our installer told us the reason was that the Mira Discovery (which they selected and supplied), when used with a combi bolier, must have the shower pressure set to full or the boiler will get confused and will cut the supply. Apparently at lower pressure settings the water spends too long in the boiler, gets too hot and then cuts off - surely the boiler should regulate this?
At full blast the pressure is so high it hurts - it feels like you have pins and needles.
We can't find the 'Eco' setting on the showerhead (which should be there according to the instruction book) so we have no way of reducing the pressure without the boiler cutting the entire water supply. I'm dubious that this showerhead setting would solve the problem sufficiently anyway.
It seems the shower and boiler are incompatible. We were told before the work started that the temperature and pressure would both be adjustable, but they aren't. We've been offered the money back for the shower (which was supposedly a freebie) but from what they've said a replacement won't be any different. It sounds to me like only an electric shower or a different boiler (like our old one, complete with hot tank) would enable us to have adjustable heat and pressure.
Can you tell me if what the installer says is true, and recommend anything we could try?
Cheers
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Mon Oct 09, 2006 11:59 am    Post Subject:
WOuld be surprised if Mira and Bosch don't work together.
Has the shower hose got twisted inside?
Suppose you turn the temp down on the boiler?
It could be the boiler isn't cutting heat down ("modulating") properly.
And I'd call Mira technical.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Modena 80e combi boiler high pressure problem 2 180 Sun Oct 11, 2009 9:30 am
HIGH pressure on combi boiler - help! 14 1740 Mon Sep 05, 2005 2:28 pm
Pressure too High on my Potterton Lynx2 Combi Boiler 4 580 Tue Nov 06, 2007 3:10 pm
Combi Boiler Tripping out on high pressure 2 300 Mon Nov 17, 2008 8:31 pm
COMBI BOILER, PRESSURE TOO HIGH 6 460 Tue Nov 25, 2008 9:25 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
