I have a Britony Combi SE Boiler and have recentley noticed that the black plastic pressure relief valve is leaking from what looks like a secondary relief outlet. The actual clear silicone pressure relief tube comes out of the valve just next to the dripping outlet\hole.
I have used a torch to see where the leak is coming from and it may be that the valve is cracked somewhere inside however i'm not too sure if it is meant to drip from this 'secondary relief outlet'?
Can anyone advise what this secondary outlet is and if it should eject water?
I have a digital photo if needed.
Thanking you for your help and time.
David
David
