Softus said:sooey said:softarse
We will have you know out soft works out and we regualrly use his buttocks to break concrete up
I don't mind at all.sooey said:I'll answer anyway if you don't mind.
And for the nth time, I know that it was - I've only said that it was irrelevant to the OP's problem, and I've been saying that all along.My original point was relevant to the question that you asked
Yawn....being as it was a direct explanation of how a high water level in an f&e cistern could cause a system to become aerated.
I don't see how quoting your own words back to you, during a discussion of the relevence of those words and accuracy of their meaning, could in any way be out of context.it was you who started to quote certain lines of the explanation back out of context, and dissected them as best you could with spurious arguments.
Not so - my arguments has consistently been that you posted about theory I'd not encountered, and that when you explained it to me I could see that is something that is not applicable in this topic.Then when you you feel that you are not getting anywhere you twist your arguments around
So how does the following admission fit in with this claim of yours:The whole point is that you ask a question and then can't accept that there is an answer that you yourself hadn't thought of
Softus said:Interesting theory - not one I'd heard before.
Until you provide a reference for the theory, it remains yours.sooey said:it's not "my theory"
Maybe it is, maybe it isn't - something that's believed by a lot of people isn't necessarily correct.it's a very well known and widely taught explanation of one way (pumping over being another) that an open vented central heating system can become aerated
Time will tell.I'm off to bed.
ChrisR said:Sooey you keep repeating the same childish silliness. You got it wrong, it was pointed out and you don't like it. Tough. Now shut up please.
...the water will expand into the already full tank and out of the overflow, causing the ballvalve to open. As the water contracts again on cooling, this then introduces freshly oxygenated water into the system.
Strictly speaking, that's an understatement.ChrisR said:Softus is a bit of a pedant
Softus said:Strictly speaking, that's an understatement.ChrisR said:Softus is a bit of a pedant
Doantcha you mean Catholic?corgiman said:...the pope is a little bit catholic
Softus said:Doantcha you mean Catholic?corgiman said:...the pope is a little bit catholic
Er, he certainly isn't, since he's not food.corgiman said:well he is as sure as heck not kosher
