DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Dyeing laminate
This topic originated from the How to page called Wooden flooring
Click here to return to the page called Wooden flooring.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
Keelinover
from Ireland
Thanked: 0 times
PostPosted: Thu Oct 26, 2006 7:39 am    Post Subject:
Dyeing laminate
Reply with quote Thanks
Hi. I am getting a retail premises done up that already has laminate flooring laid by the previous owner, however it is the wrong colour. Does anyone know if I can use a dye over the laminate - and what will be the process to do this? Or will I just have to cut my losses and lay new flooring?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Keelinover
from Ireland
Thanked: 0 times
PostPosted: Thu Nov 02, 2006 3:15 pm    Post Subject:
hi,
does anyone know if it is possible to dye laminate floor darker or will i have to re-lay a new floor ?
thanks
K
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 24 times
PostPosted: Thu Nov 02, 2006 3:34 pm    Post Subject:
heeelllooo keelinover and welcome icon_biggrin.gificon_biggrin.gificon_biggrin.gif
if its the cheap stuff this is only chipboard or mdf with a paper printed desighn with a plastic coating so no not realy [in my opinion icon_wink.gif ]
if its more expensive stuff with real wood veneer usualy around 12mm thick you have a chance to remove the finnish and re colour
but as the veneer is so thin your unlikly to remove all the finnish before you remove the veneer
and if you dont get all the finnish off youll get patchy results
having said that if you can disolve rather than sand the finnish you may be ok
but nothing in my opinion will work on the photo printed cheap stuff
good luck
__________________
big all
we are------------------ all still learning
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Which glue should I use for gluing Door Bar down on laminate 2 300 Wed Dec 05, 2007 3:02 am
cutting shape in laminate / wood flooring 5 580 Sun Dec 02, 2007 5:56 pm
Laminate flooring putty is darker than tile. HELP!!!! 7 700 Thu Nov 29, 2007 9:59 am
Laminate Flooring 3 520 Mon Dec 17, 2007 3:23 am
Laminate Flooring 4 520 Wed Dec 19, 2007 8:02 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
