Indesit WD125 Not Draining Properly?
28 Oct 2006
Tyne and Wear
Hi people!
My Indesit WD125 is not draining correctly.
I checked then end of the hose for blockages but not any.
I put the hose in a bucket and put the washing machine on a 30 degree wash and when it came to drain the water flew out for the first 2 seconds then went to a trickle, a noise kicked in (buzzing) sounding as if the pump was blocked, then machine then stopped after around 3 minutes of attempting to drain to click around and flash (When stopped water still inside machine at bottom).
When i put my machine on a spin however i got a full bucket of water and spin cycle went correctly.
Any suggestions please? Do you think the pump is blocked?
I dont have the instructions also!
Thanks. :)
Probably blocked filter.
Possibly blocked drain hose or blocked pump.
