simmy
Joined: 01 Nov 2006 Posts: 2 Location: Edinburgh, United Kingdom Thanked: 0 times
Posted: Wed Nov 01, 2006 11:43 am Post Subject: 2 way dimmer switch wattage |
As a relative novice to lighting electrics at home and this forum, I have a query regarding the wattage quoted on dimmer switches.
I want to replace one of my current 2 way switches (single switch which turns on 2 main lounge lights together) for a 2 way dimmer switch.
The 2 way dimmer switch I have quotes wattage up to 400W. The dimmer switch would operate both of the 2 main lounge lights together - each light fitting has 5 x 60w golf ball bulbs i.e. 300W on each. Does this mean I need to find a dimmer switch with wattage up to 600W ??
Is it ok to use a single dimmer switch to operate 2 main lights like this, as I don\\\'t really want to have to put in wiring to operate the 2 main lounge lights separately? |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Wed Nov 01, 2006 10:51 pm Post Subject: |
fraid it does.
60 x 5 x 2 =600
the word way, in respect of 1 way or 2 way is for how may switches you have. (but that said doesnr mean you cant use a 2 way switch for one way, but you cant use 1 way switch in a 2 way cct)
and yes also it does not count any intermeadite swithces __________________ Do you like music Mr Finch?
Forum = Opinions |
