richplumb
Joined: 07 Nov 2006 Posts: 1 Location: West Midlands, United Kingdom Thanked: 0 times
Posted: Tue Nov 07, 2006 9:44 am Post Subject: Add a rad to a combi system |
I want to add a small radiator downstairs to a combi boiler system.
Do I need to drain the whole system or could I get away with simply relieving the system pressure and closing all radiator valves? |
MANDATE
Joined: 06 Mar 2003 Posts: 1496 Location: Manchester, United Kingdom Thanked: 10 times
namsag
Joined: 12 May 2004 Posts: 7929 Location: United Kingdom Thanked: 59 times
Posted: Wed Nov 08, 2006 7:24 am Post Subject: |
As a diyer it will be far easier to just drain a pressurised combi system as they usually empty and fill quite quickly. But there is a way of doing it full, If boiler has half decent isolating valves turn these off then release pressure from system either from a drain cock or a bleed point on a rad when water stops close whatever you have used. When you now cut into pipes you will get a minimal amount of water l come out allowing you to connect new pipe work etc even using soldered joints but there is a knack to it. |
sm1thson
Joined: 05 Sep 2005 Posts: 829 Location: Hull, United Kingdom Thanked: 0 times
Posted: Wed Nov 08, 2006 10:08 am Post Subject: |
draining also means you get to replace the smelly old water with new stuff (might be worth i diy flush at the same time? -see the wiki), when you add new water dont forget to add inhabiter to keep it fresh! |
