immersion heater spur/plug
7 Nov 2006
Glasgow
i have just moved into a flat that was built in teh 1900s and renovated in 1980. the flat is electic only and has a immersion heater for hot water. heating rooms is done through wall mounted electric heaters.
i switched on the immerser for the second time last night for 30mins. when i switched it off the spur/face of the switch (i dont know the technical terms for the parts) was very warm.
i would say it was similar in warmth to the power supply of a laptop. not enough to burn my hand but very warm to the touch.
is this normal?
after 30mins there was no hot water to wash dishes.
however, we have had it on once before and it did provide hot water and i dont recall the spur/plug/face being warm.
any ideas?
a 3 KW immersion heater connected to a fused connection unit with a 13A fuse in will cause the FCU to run warm. So long as the FCU is not wrapped up in a duvet this isn't a problem.
However, if youre immersion heater has stopped working, this implies a fault. you should get an electrician to check - a faulty immersion heater has the risk of being very dangerous due to all the water involved etc.
ah, well at least its supposed to get warm. ill get a spark into have a look if it continues not to heat up the water.
It may also become warm because there is a faulty connection inside.
Good advice to get it checked out.
TTC
