DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Switching a bathroom sink over and inst a pillar mixer tap
This topic originated from the How to page called Installing a bathroom sink
Click here to return to the page called Installing a bathroom sink.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
vlangford
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 13, 2006 10:13 am    Post Subject:
Reply with quote Thanks
I have never done plumbing, but it looks quite easy after looking at the back of the sink unit. Thats what Im worried about. I have bought a new sink unit, which has a tall pillar mixer tap with two flexible hoses for the water with a male connector on the ends. The current sink is a standard two tap sink with pipes already connected with what look like nuts. How do I connect the flexible hoses to the copper pipe as th new tap hoses have \\\"nut\\\" like ends and the pipe wont after I have had to cut them, I think the waste pipe is the same height so that shouldnt be a problem. but im worried I will try this and it will all go horribly wrong becasue I dont know what im doing or whether i am missing something. Help!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Mon Nov 13, 2006 12:11 pm    Post Subject:
No, you've got the idea, in the middle there:
Your instinct for caution is god's way of telling you to buy a book icon_biggrin.gif
Back to top
 Alert Moderators
Slugbabydotcom
from Pakistan
Thanked: 3 times
PostPosted: Mon Nov 13, 2006 12:16 pm    Post Subject:
Quote:
it looks quite easy
And by the end of the post we see
Your lack of confidence has shone through.
Pay someone to do it for you.
If they dont mind you watching them do it then you can learn and next time round you may be able to do it yourself
__________________
Eagles may soar high but Slugs" don't get sucked into jet engines
Back to top
 Alert Moderators
vlangford
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 10:36 am    Post Subject:
sheesh
Thanks muchly to both contributors! im now completely none the wiser! icon_lol.gif
I'd love to get someone to do it, but in Whitehaven I think there is precisely one plumber, and he is busy for the next ten years it seems.... my bathroom has two sinks and two toilets and my son keeps getting confused which loo to use to my utter dismay. (hes only 3.5)
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Nov 20, 2006 11:52 am    Post Subject:
Re: Switching a bathroom sink over and inst a pillar mixer t
Hi vlangford
If you're going to tackle this yourself then you'll have to treat it as a project, some parts of which will be easy and some difficult.
The first thing I would say is that you might be disappointed in the water flow from your new pillar tap. BTW, if your sink is in a bathroom then it's called a basin. icon_wink.gif
Generally, you need to break the job down and tackle one thing at a time. For example:
1. Find the isolating valves for the hot and cold services, and shut them off. This can become a project on its own if the valves don't work.
2. Disconnect the pipes from the taps, disconnect the waste from the trap, and remove the basin.
3. Install the tap tails onto the tap and the tap onto the new basin.
4. Install the waste kit onto the new basin.
5. Install the new basin. If there are Fischer bolt slots, then use Fischer bolts.
6. Connect the trap and connect up the waste. It might need altering.
If I were you I'd buy a new trap, 'cos the old one will probably be unpleasant.
7. Connect the water supplies to the tap.
8. Reinstate the supplies, testing one before turning on the other.
To answer some of your specific questions
It sounds like you have flexible hoses with compression connectors, so just cut the pipes at the right height (plus a bit) and you'll be able to make on the connections.
You might want to get an adjustable trap, just in case the waste doesn't line up as you think it will.
Back to top
 Alert Moderators
Joeylegend
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 1:41 pm    Post Subject:
You can but a copper connection to join the copper pipe
i had the same problem, you can buy a copper fitting in the BIG DIY stores that will connect the flexible tap hose and then will connect to the copper pipe. therefore joining the whole lot together ,go to the DIY store and study out all the fittings you will find one.
Back to top
 Alert Moderators
vlangford
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 22, 2006 7:02 am    Post Subject:
Will let you know how it goes! I successfully removed a radiator yesterday and was immensley proud of myself (how sad am I) well, single mum and all that, I gotta try to save pennies if I can...safely of course.
Back to top
 Alert Moderators
vlangford
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 22, 2006 7:12 am    Post Subject:
Slugbabydotcom wrote:
Quote:
it looks quite easy
lol, thanks, but as a single parent, and a whole house needing doing, I have to save my money on getting electricians out-not even going there with touching electrics! at least I can try the plumbing as ai can turn the water off safely. I managed to remove a radiator (small project I know, but for a novice with no plumbing experience I felt mighty proud-not to mentiont he fatc I saved a lot of money!)
Back to top
 Alert Moderators
vlangford
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 22, 2006 7:13 am    Post Subject:
Softus wrote:
Hi vlangford
Im certainly going to give it a go, worst case scenario is that I have to get a plumber out to install them, but I wont have to pay out for his removing the old ones icon_smile.gif Thanks for the advice! Here goes...
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Replace Potterton Prima 50 B ( inst 1996 ) with a condensor 6 220 Sat Dec 06, 2008 3:42 pm
Can I check if a powerflush was done with my new boiler inst 43 1720 Sat Aug 09, 2008 7:12 pm
New chrome pillar needed to support bathroom sink 11 720 Wed Jul 19, 2006 11:21 pm
Changing a normal pillar tap washer-please help! 3 320 Mon Aug 18, 2008 11:38 am
Astracast pillar tap 11 340 Sat Mar 08, 2008 12:26 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
