carlvalley
Joined: 12 Aug 2006 Posts: 9 Location: Anglesey, United Kingdom Thanked: 0 times
Posted: Mon Nov 13, 2006 10:45 am Post Subject: Extractor flue to flat roof |
Hi Please help!! I wish to install a chimney hood to a new kitchen, i have my heart set on extracting the air outside as i've heard its much better than the filter type, my problem is, i cannot run a extractor duct pipe through the wall as i live in a terrace, is it possible to run the extractor pipe up through a flat roof? If so will i need a turn at the roof to prevent water coming down the air brick? I would be grateful if you could help.
Thanx!! |
noseall
Joined: 02 Feb 2006 Posts: 11053 Location: Staffordshire, United Kingdom Thanked: 71 times
Posted: Mon Nov 13, 2006 5:24 pm Post Subject: |
you can successfully vent through a flat roof no problem by fitting a mushroom vent terminal on top.
you will need a flat roof specialist to make good though. |
