stoney24
Joined: 14 Nov 2006 Posts: 2 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Tue Nov 14, 2006 8:16 pm Post Subject: Joining cable in plaster |
I want to move a socket that is on a brick wall, I only want to move it about a meter so it is behind the TV. Where the socket is now is unsightly so I want to completely remove it and plaster over the hole, but if I do this I wont be able to wire my new socket into anything. Could I put a junction box into the hole and plaster over it? If I cant use a junction box could I use anything else? |
industryspark
Joined: 08 Jul 2006 Posts: 567 Location: Yorkshire, United Kingdom Thanked: 1 time
Posted: Tue Nov 14, 2006 8:20 pm Post Subject: |
junction box's should be accsesible for inpection and you certainly cant bury it in the wall.
hows about replacing the whole length of cable from the last socket? best solution. __________________ remember......a little bit of knowledge is often more dangerous than no knowledge at all! |
RF Lighting
Joined: 31 Mar 2006 Posts: 10753 Location: Birmingham, United Kingdom Thanked: 73 times
stoney24
Posted: Tue Nov 14, 2006 10:12 pm Post Subject: |
Thanks for the replys. I have had a look at the socket i want moved and the cables go up the the wall and into the ceiling, it's goning to be difficult to get at the floor boards upstairs as i've had tiles and wooden floor laid. would it be possible to put a blanking plate where the original socket is and could i use 30A terminal block to make the joint behind the blanking plate? |
RF Lighting
