Help TRV Not Closing Leaking
7 Mar 2006
Shropshire
i have taken a couple of radiators off because we are having some work done i have turned the trv valves down as far as they go to the frost setting because it is so cold in the room i believe the valves are starting to open hence starting to leak is there anything i can to buy to replacethe trv and close the valve without it opening
cheers brett
Decorating caps. Or a float valve washer over the pin.
you can also put such a cap on the end of the valve where the big nut on the radiator tail normally screws on.
Stops dripping valves.
i have wound a flexible tap connector with an isolator on it so that when you come back to put the rad back on you can drain off the excess
works well that does
