Joined: 20 Nov 2006 Posts: 3 Location: Suffolk, United Kingdom Thanked: 0 times
Posted: Mon Nov 20, 2006 2:33 pm Post Subject:
Which circuits need MCB\\\'s?
Hello, I\\\'m just replacing the conglomeration of old fuseboxes etc in my garage/office with a new Wylex Consumer unit. Which circuits need to be wired into the MCB\\\'s? I have the following circuits:- Lights(6A); Ring Main(32A); One storage heater(16A); Underfloor heating(16A); To shed(16A); To Greenhouse(16A). Also how deep should I chase the wall for the cables for the underfloor heating? Thanks in advance.
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Mon Nov 20, 2006 3:16 pm Post Subject:
Any which feed socket circuits likely to supply portable equipment outdoors such as the ring, the shed and the greenhouse. You may also find the manufacturere specifies RCD protection for underfloor heating.
I am taking it that its a TN supply?
Joined: 15 Aug 2004 Posts: 729 Location: United Kingdom Thanked: 5 times
Posted: Mon Nov 20, 2006 9:49 pm Post Subject:
RCD.
The only circuit legally required to be on a RCD (well at present) is the downstairs ring final circuit, as it can supply equipment out of doors, the others are optional or not always necessary.
If your cooker circuit has a socket, then it must be RCD protected, likewise any shed or garage or garden power sub-circuits (if any).
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Mon Nov 20, 2006 9:58 pm Post Subject:
Cooker circuit needs an RCD if it has a socket that "can reasonably be expected to supply equipment outside".
So if it is not close to the back door, and there other sockets closer, then prob not necessary. E.g. my cooker circuits are on the first floor.
It is better to have a cooker switch without a socket to avoid this quandary, also to make it more difficult to plug the kettle in and drape the flex across the hob so it can get burned.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
