I moved into a new house, only to find the shower had a cheap nasty thermostatic plastic valve - which had settled on 2 settings - cold or red hot.
The house has a new Woucester Boiler (combi condenser). I replaced the plastic shower valve with a Sirrus 1503 thermostatic valve.
Now I find that the water from the shower gets hotter, depending on how far you turn the dial which is right. However, after about 2 mins the flowrate beings to alter, pulsing, then becoming weaker and then increases and is cold for a while. This is worse the hotter it is set.
The cold feed does have a govenor, which I turned in an attempt to see if the previous plastic valve could be fixed.
I thought that the rate might be dropping off because the cold pressure is too low - but I'm a bit stuck
Any suggestions, would be most gratefully recieved -
Thanks Matt.
Thanks Matt.
