DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
How to repair corrosion hole in backwash lead drain pipe
This topic originated from the How to page called Repairing a burst pipe
Click here to return to the page called Repairing a burst pipe.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
lzahn
from United States of America
Thanked: 0 times
PostPosted: Wed Nov 29, 2006 4:50 pm    Post Subject:
Reply with quote Thanks
Yesterday I found a fairly large hole in the end of a pipe I believe is lead that is used for overflow for water coming from a bathroom sink. The house if about 90 years old and I really don't want to have to replace this pipe. Is there a way to patch /repair this hole? Its at the end of a pipe, that I guess is filled with lead and one of the edges where the filling meets has corroded through. I am afraid if I call someone to fix this they will surely want to replace it, but I just want to patch it at this time. How is this done? Sodering? Sealant? And keep in mind its just an overflow area.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Wed Nov 29, 2006 9:44 pm    Post Subject:
Qute easy, if you get the right solder. It has to be the type used for "wiping" joints. In UK it's called type D and sold in sticks about 1.4" x 3/4".
You can either build up the edges of the pipe, or (easier) get a piece of lead , flashing or pipe, cut it a bit oversize, and solder it on.
You have to scrape everything scrupulously clean. Ordinary copper jointing flux will do.
Trick is to GENTLY heat the pipe, and the stick solder at the same time. Just after the "haze" goes from the pipe, the solder will melt onto it quite easily. I suggest you don't worry about the aesthetics, just get the metal seal complete. Afterwards you can fuss with it, though filing it might be safer. With practise you can "wipe" the thing smooth while the solder is still only partly frozen- depends how many you were intending to do!
Have a practise on some scrap first. It is possible after a few trials, to use ordinary plumbers solder or even the electronic one.
Back to top
 Alert Moderators
Slugbabydotcom
from Pakistan
Thanked: 3 times
PostPosted: Thu Nov 30, 2006 1:30 am    Post Subject:
Why not?
If you are in the US they might have a different grading system for the solder there. Might be better to try a US DIY site for help
__________________
Eagles may soar high but Slugs" don't get sucked into jet engines
Back to top
 Alert Moderators
tsunami
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 30, 2006 7:28 am    Post Subject:
Just use some grey two part epoxy putty.usually available in plumbing and diy merchants.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Copper pipe corrosion. 10 2440 Sun Aug 26, 2007 6:16 pm
Copper pipe corrosion 6 2000 Fri May 23, 2008 7:36 pm
Corrosion/rust on Chrome radiators and all bathroom fittings 3 660 Mon Oct 13, 2008 10:40 pm
Advice On Adding Corrosion Inhibitor Please ?? 4 420 Sat Dec 22, 2007 1:11 pm
Corrosion inhibitor 3 440 Sun Jul 15, 2007 2:37 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
