DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
ceiling rose with hook
This topic originated from the How to page called Adding a new light and switch
Click here to return to the page called Adding a new light and switch.
  View previous topic :: View next topic
Author Message
nadiar
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 03, 2006 7:19 pm    Post Subject:
Reply with quote Thanks
Not so much an electrical question as a practical one -- we are trying to replace a standard 9cm plastic ceiling rose with a metal one incorporating a hook in order to suspend a glass light on chains. We were originally sold an 11cm one on the grounds that "as long as it's bigger than the one it's replacing, it will be fine", but the distance between the screw holes is too narrow to allow it to be attached over the existing back plate. We subsequently bought a second hook, which is the same diameter as the plastic rose, and has screw holes in the same position. However, it is completely flat across its base, whereas clearly the wiring on the backplate is slightly proud of the wall, so it is hard to see how we are going to achieve a secure fit by simply screwing it in over the top. Any suggestions (preferably not involving more expenditure!!)?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Jaymack
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 03, 2006 8:46 pm    Post Subject:
Re: ceiling rose with hook
I think what you need is a junction box with terminals fitted inside: -
http://www.screwfix.com/app/sfd/sea/searchresults.jsp;jsessionid=KS5HYTCQXSSTICSTHZPCFEY?_dyncharset=UTF-8&howMany=15&searchText=chocbox&x=15&y=13
This can be pushed up inside the existing hole access to the light fitting, which I assume is going to be earthed.
Jaymack
Back to top
 Alert Moderators
nadiar
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 07, 2006 12:18 pm    Post Subject:
thanks Jaymack and sorry, am fitting to ceiling obviously but am suffering from baby-brain...! Don't worry, it won't be me doing the wiring!
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Ceiling light fitting with hook 3 480 Sat Mar 17, 2007 7:05 pm
Camping hook up - Transformer 13 420 Sun Jul 13, 2008 2:13 pm
Ceiling Rose lighting 9 400 Tue Sep 27, 2005 4:00 pm
can i add a 12v downlight to a ceiling rose 3 620 Mon Jan 14, 2008 1:52 am
Ceiling rose to L/E/N 2 240 Wed Jan 16, 2008 3:41 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
