Ganja
Joined: 06 Dec 2006 Posts: 1 Location: Lancashire, United Kingdom Thanked: 0 times
Posted: Wed Dec 06, 2006 6:43 pm Post Subject: removed a radiator |
i have a 2 pipe system and i have removed a radiator capping each pipe off separately there are 2 radiators now not working could this be down to capping the pipes off seperatly rather than linking them together |
sime10
Joined: 19 Oct 2006 Posts: 728 Location: Cardiff, United Kingdom Thanked: 0 times
Posted: Wed Dec 06, 2006 6:54 pm Post Subject: |
Did you drain the system? or did you just drain the rad?
If you drained the system it maybe air in the 2 not working
If you blanked the valves without draining nothing should be wrong just coinsidence try turning all working rads off and see if the 2 get hot. __________________ You live to learn and Learn to live |
