varanik
Joined: 12 Dec 2006 Posts: 1 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Tue Dec 12, 2006 10:52 am Post Subject: Extractor fan puzzle. |
I moved into a new house and the bathroom\\\'s extractor is not working (just a little red light but fan itself is dead). I have an on off switch for it (in the boiler cupbord) and it is activated by switching on or off the light.
I have removed the old fan and I have two wires (red and black). I purchase a new fan with a timer connected it but it comes on only for a couple of seconds then stops. I attempted all possible combinations on the three L N and L1 inputs on the fan. I gave up and decided the fan might have been faulty so went out bought a different model and this one doesn\\\'t even turn on for a second. Have I killed both? what am I doing wrong
Paolo |
didthathurt
Joined: 19 Aug 2006 Posts: 311 Location: Kent, United Kingdom Thanked: 0 times
Posted: Tue Dec 12, 2006 10:53 am Post Subject: |
A timer fan requires 3 feeds, a live, switched live and a neutral. See the sticky for info. __________________ Being a professional doesn't mean I'm any good - just that I get paid for doing it! |
Spark123
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Tue Dec 12, 2006 12:18 pm Post Subject: |
If you link L to Ls on the fan then it should work. |
tiendu
Joined: 21 Dec 2006 Posts: 1 Location: Surrey, United Kingdom Thanked: 0 times
Posted: Thu Dec 21, 2006 9:36 pm Post Subject: Live and Switched Live |
I have only one red and one black cable from the wall while my timer fan has switched live and permanent live cables. As you had suggested, should I connect both the switched live and permanent live on the fan to the red cable on the wall? Will this work, as I found that by connecting either permamnet live or switched live to the red cable separately will not work.
| Spark123 wrote: | | If you link L to Ls on the fan then it should work. |
