DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
7 fingered wood block
This topic originated from the How to page called Wood block / Parquet floors
Click here to return to the page called Wood block / Parquet floors.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
new owner
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 21, 2006 12:49 pm    Post Subject:
Reply with quote Thanks
we have just bought a new house which has wood block flooring laid in 2 rooms. Can you tell me where we can get some 7 fingered oak wood block to match the exsiting floor. We want to remove a large wardrobe but the wood block was not laid under the wardrobe, it is bare wood floor boards. Can you help? icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Thu Dec 21, 2006 12:56 pm    Post Subject:
Hi new owner, welcome
If you can give us the measurements of the mosaic block (tickness etc) we might be able to help out, depening on how much sq meters you need.
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
new owner
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 29, 2006 10:02 pm    Post Subject:
Hi wood you like!
The area we need to cover is quite small it measure 21 inches by 75 inches - sorry I measured in imperial size. Each 7 fingered block measures 6 inches or 152 mm square. We are not able to tell the thickness of the wood block but the gap from the floor boards to the flooring in probably about 2cm. Looking at the space within the built in wardrobe the flooring may be sat on 1.5cm thick board. (We haven't pulled the wardrobe out in case we are not able to get any block to fill the hole). If you are to help could you give me some idea of the costing. Sorry I don't know what you mean by the ticking but hopefully I have given you all the measurements you need.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri Dec 29, 2006 10:07 pm    Post Subject:
Back to top
 Alert Moderators
new owner
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 29, 2006 10:19 pm    Post Subject:
from the measurements we took we are summising the thickness of the block is 5cm but hopefully someone may know from the size of the block if this sounds feasable!!
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Sat Dec 30, 2006 9:38 am    Post Subject:
JohnD wrote:
Hi new owner. Have to check the measurements of the mosaic tiles we have (not stored in shop), but 5 cm is very,very thick. Normally it would be either 20mm or 8mm thick, not 50mm.
__________________
Back to top
 Alert Moderators
new owner
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 01, 2007 8:17 am    Post Subject:
Hi JohnD
We have now taken the wardrobe out as we had a plasterer coming in to do the walls. The blocks have been laid onto plywood - I will check the thickness today and let you know the exact thickness of the blocks. Also I can be more specific about the measurements of the hole we need to fill.
Happy new year. Hope your not too hung over this morning after celebratations!! icon_wink.gif
Back to top
 Alert Moderators
new owner
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 01, 2007 8:45 pm    Post Subject:
7 fingered board
Hi John D
rechecked measurements the blocks are 8mm thick sat on plywood that is 13mm thick.
We need to fill a space 183.5cm with 25mm chopped out of the next block by 58 cm. Each set of 4 7 fingered blocks forming the pattern, measure 305mm square. icon_neutral.gif
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Tue Jan 02, 2007 9:08 am    Post Subject:
Hi new owner
we have mosaic Oak 8mm thick 7 fingers, where one block of 7 fingers measures 16cm by 16 cm.
__________________
Back to top
 Alert Moderators
new owner
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 02, 2007 9:16 pm    Post Subject:
I had assumed the wood block came in 4 squares already joined together making up the pattern of each square of 7 fingers laying at 90 degree angle to each square of 7 fingers. does this mean we can buy each single square to make different patterns. The squares you have are the correct thickness but appear to be larger. Ours measure 6inches or 152mm. Can you tell me the cost of each square. Is there a minimum order? How much for delivery? Whereabouts are you could we collect?
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Wed Jan 03, 2007 10:02 am    Post Subject:
Our mosaic tiles are 2 by 4 squares of 7 fingers = 32 cm by 64 cm total = 0.20 sq m per tile. (mosaic is Rustic Oak, unfinsihed)
We're in Kent (near Ashford), so it's up to you (delivery charge would be IMHO more than the price for the tiles)
__________________
Back to top
 Alert Moderators
new owner
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jan 04, 2007 9:27 pm    Post Subject:
so how much per tile? if we buy a pack - how many tiles in a pack and how much per pack?
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Fri Jan 05, 2007 9:59 am    Post Subject:
Re: 7 fingered wood block
Give us a call and we can discuss details (see profile for website = website is phonenumber (contact details)
__________________
Back to top
 Alert Moderators
new owner
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 07, 2007 8:59 am    Post Subject:
sorry i am a real rookie. I cannot find your profile to contact you. please post the details
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Sun Jan 07, 2007 9:18 am    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Sub Floor for Wood Block Flooing 4 220 Mon May 18, 2009 10:49 am
Restoring wood block floor 3 280 Wed Jul 29, 2009 9:08 am
Laying reclaimed wood block flooring 2 400 Tue Feb 24, 2009 5:05 pm
Precedure for oak block wood flooring 5 2080 Tue Jan 09, 2007 8:00 pm
water damage to wood block 2 2400 Fri Jul 28, 2006 7:02 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
