chambers
Joined: 02 Jan 2007 Posts: 3 Location: London, United Kingdom Thanked: 0 times
Posted: Tue Jan 02, 2007 5:47 pm Post Subject: Potential bad earth |
i have recently purchased a new lamp for my bedroom and its one of these new touch lamps, touch the metal base and it witches off and on. The issue i have is that when i use it in my bedroom sockets i have to earth myself to allow it to work, when using it in other rooms i have no issues. Although i can get a new lamp i am now concerned that i may have a bad earth circuit. Any thoughts. |
jj4091
Joined: 01 Dec 2006 Posts: 1794 Location: Cumbria, United Kingdom Thanked: 8 times
Posted: Tue Jan 02, 2007 7:03 pm Post Subject: |
Do you have different floor covering in the rooms? |
chambers
securespark
Joined: 11 Jan 2004 Posts: 16480 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Tue Jan 02, 2007 8:40 pm Post Subject: |
If you're worried about using this type of lamp, don't! __________________ As George Michael once said, "..if you're gonna do it, do it right, right?" |
Adam_151
Joined: 17 Jun 2004 Posts: 4538 Location: United Kingdom Thanked: 10 times
Posted: Tue Jan 02, 2007 8:49 pm Post Subject: |
What happens if you put it in one room and run it off an extension cord from the other room? (and try it both ways round) |
chambers
I was more woried about have a bath earth connection rather than the lamp. I will get a crcuit tester to put my mind at rest. |
sm1thson
Joined: 05 Sep 2005 Posts: 829 Location: Hull, United Kingdom Thanked: 0 times
Posted: Wed Jan 03, 2007 9:32 am Post Subject: |
note that a circuit tester (such as a plug in socket tester) will only tell you if there is some kind of earth etc it does not measure it to see how good it is unless you spend hundereds on a proper sparks unit. (although a few quid on a socket tester is handy as long as you bear the above in mind).
do the test adam suggested that will tell you a lot. |
