DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fitting new taps
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Donna_
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 05, 2007 10:21 pm    Post Subject:
Fitting new taps
Reply with quote Thanks
I recently bought a two holed mixer tap for my kitchen sink and tried to fit it myself.... i removed the old ones, then the new ones were slightly too long so i sawed the ends off and fitted them. Now when i turn the tap on the water leaks from the join at the top. I have bought a file and some new washers and ptfe tape and plumbers putty. will any of this help or am i going to have to call a plumber? oh and i undid the compression valve at the bottom and i think that leaks a bit too.... please can anyone help me ? icon_sad.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
uug197h
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 05, 2007 11:52 pm    Post Subject:
make sure the surface is flat then use a rubber washer on them, the service needs new ptfe round the olive and tighten back up
Back to top
 Alert Moderators
Donna_
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 05, 2007 11:56 pm    Post Subject:
thanks! i have got fibre washers (red ones). will they do or do i need to go back to b&q?
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 400 times
PostPosted: Sat Jan 06, 2007 12:25 am    Post Subject:
you need to get the ends you cut flat and square if you still have the old backnuts screw one on and use it as a guide if it isn't square to the thread it won't seal icon_wink.gif
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
Lee-King
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 06, 2007 12:27 am    Post Subject:
Fibre washers should be just fine.
Back to top
 Alert Moderators
Donna_
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 06, 2007 12:33 am    Post Subject:
thankyou all. this site is great, none of the diy websites have helped me a t all. i thought i'd ruined them but it seems fixable. hopefully i'll get it fixed tomorrow and won't have to do the washing up in the bath anymore icon_smile.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
BUILDING REGS fitting isolation valves to cold and hot taps 8 4400 Thu Jan 04, 2007 8:20 am
Taps noisy after fitting new tap washers 2 660 Fri Sep 09, 2005 5:09 am
Fitting basin taps to bath? 8 640 Sun Sep 23, 2007 11:09 am
fitting new taps 9 420 Sat Jan 27, 2007 9:08 pm
Fitting Basin Taps 2 340 Fri Dec 30, 2005 11:17 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
