I have installed an in-line extractor fan from my shower enclosure, into the loft space and horizontally out through a gable wall.
The run is quite long (about 7m).
The problem is, I had to use flexible ducting on the stretch upstream of the fan (noise was too high with rigid soil pipe bend on ceiling spigot). Now I am getting a lot of condensation in the flexible section, causing it to sag.
It's difficult to find the right rigid/flexible combination to get the necessary low noise and yet get drainage correct. I know that condensation traps are available, but will they work in a horizontal run. I know I need to insulate the duct, but will this eliminate condensation completely, in an un-heated loft space? Can I just lay glass fibre blanket over the pipe, or do I need to lag it with proper pipe insulation.
Any advice would be greatley appreciated.
