Indesit WD12x door won\\\'t open
7 Jan 2007
Coventry
Really stuck here. After cycle door would not open leaving all of the clothes stuck inside. Is there any way of manually opening the lock from the inside as the machine is part of a fitted kitchen and I really want to avoid having to get all of the pipes out as they are behind other units and appliances. Thanks
The door may be jammed because the machine has not drained all the water out?
Try a spin/drain cycle & then wait a couple of minutes. If it hasn't drained then the easiest way to drain it manualy is to put the drain hose (Grey flexible) into a bowl on the floor and let the water syphon out.
Once drained the door should open, you then need to check the filter for a blockage. :rolleyes:
Good luck!
