Pipe sizing - fixed shower head
7 May 2006
Im just plumbing in my new thermostatic shower the hot and cold feeds enter the thermostatic shower in 15mm.
I'm not sure if I should pipe the output to the showerhead in 15 or 22mm ?
Boiler = combi
If the inlets are in 15mm, you won't gain anything by doing the outlet in 22mm. 15mm outlet to the shower head will be fine.
Cheers - I was all set to plumb it in 15mm and then thought with 2 X 15mm feeds into a 15mm outlet I may create a bottleneck.
Is the combi(11l/min) the real bottleneck in this situation?
EDIT: Just to add, Ive measured my mains water pressure at a good 3bar
long as the shower mixer is suitable for a combi , all should be OK
