DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Transformer for electro magnetic door lock?
Goto page 1, 2, 3, 4  Next
Author Message
coopersim
from United Kingdom
Thanked: 9 times
PostPosted: Thu Jan 25, 2007 6:15 pm Reply with quote
I have an electro magnetic door lock, it is rated 24 volts 3 watts, can anyone advise of a suitable transformer to run this from?
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 972 times
PostPosted: Thu Jan 25, 2007 6:21 pm Reply with quote
First two questions ?
Is it an AC ( alternating current ) or DC ( direct current ) lock ?
Is it energised to lock ( fails to open on power failure ) or energised to release ( cannot be opened remotely during a power failure )
Back to top
 Alert Moderators
coopersim
from United Kingdom
Thanked: 9 times
PostPosted: Thu Jan 25, 2007 6:25 pm Reply with quote
1. It's DC rated
2. It's energsied to lock, so will release when power is removed
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 972 times
PostPosted: Thu Jan 25, 2007 6:33 pm Reply with quote
RS Components Stock No 310 2014 or 541 7560
Battery backed 24 volt 24 volt 1 amp ( more than you need but means the unit is not stressed and expansion is possible )
Other sources are available but for speed and convenience RS is worth the extra cost.
Back to top
 Alert Moderators
coopersim
from United Kingdom
Thanked: 9 times
PostPosted: Thu Jan 25, 2007 7:47 pm Reply with quote
Thanks for the info - however I'm not bothered about the battery backup element - just a cheapy transformer !! I'll have a look on RS Spares though, thanks again.
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 972 times
PostPosted: Thu Jan 25, 2007 7:57 pm Reply with quote
It is NOT a transformer you need. You need a power supply with transformer and rectifier and smoothing capacitor. Without the capacitor the lock may buzz as the rectifier will be giving raw DC ( on-off 100 times a second ).
Back to top
 Alert Moderators
coopersim
from United Kingdom
Thanked: 9 times
what about this one - 418-2443
or this one - 347-7144 ??
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Thu Jan 25, 2007 8:08 pm Reply with quote
Dont they sell proper power kits for these locks? All the mag locks i've seen have a white box on the wall above the door, with power healthy, battery healthy lights.
The box contains all the electronics for the system, and releases the door on closing an external contact (push to release switch or numeric keypad)
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 972 times
PostPosted: Thu Jan 25, 2007 8:17 pm Reply with quote
My only concern with switch mode power supplies is there is more to go wrong in them. And they can be a source of interference to nearby electronic equipment. Sometimes they have to have a minimum load and removing all load can cause them to lock up. The data for these two does not mention a minimum load requirement
Sometimes the back EMF from a switched inductive load will trigger the over voltage protection. You will need a back EMF diode across the coil and maybe some additional suppression in the form of a capacitor on the output of the power module
Back to top
 Alert Moderators
coopersim
from United Kingdom
Thanked: 9 times
PostPosted: Thu Jan 25, 2007 8:22 pm Reply with quote
This isn't as simple as I first thought! I'm prepared to spend about 30, what would you suggest in this instance? It is only for domestic installation, but there is sensitive electronic equipment in the area where it will be installed - namely a wireless ADSL router and a wireless alarm system
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 972 times
PostPosted: Thu Jan 25, 2007 8:58 pm Reply with quote
Nothing is as simple as it looks. As Crafty mentioned the makers of the lock may have something in their range.
I will have a think and get back tomorrow.
Back to top
 Alert Moderators
coopersim
from United Kingdom
Thanked: 9 times
PostPosted: Thu Jan 25, 2007 9:02 pm Reply with quote
I agree! However, there is no make on the lock, it is a simple lock that I bought from a local electronics shop with no box, the chap I spoke to suggested a 'laptop style' transformer, but I really want something that I know will be adequate.
Any ideas would really help.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Thu Jan 25, 2007 9:14 pm Reply with quote
any chance of a pic?
or more info?
is it really a mag lock?
does it have2 parts or one?
does it look like
or
Back to top
 Alert Moderators
coopersim
from United Kingdom
Thanked: 9 times
PostPosted: Thu Jan 25, 2007 9:28 pm Reply with quote
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Thu Jan 25, 2007 9:31 pm Reply with quote
so its a white box with a red cross, not seen that one before
Back to top
 Alert Moderators
Page 1 of 4
Jump to:
Sunvic MP2 Electro-Mechanical Programmer CB3303 5 300 Fri Aug 27, 2010 5:56 pm
Fitting Magnetic Alarm Door Surface Contacts on uPVC 9 2620 Sat Mar 10, 2007 2:04 pm
Fitting a magnetic alarm to a upvc door 7 4720 Sat Sep 09, 2006 5:46 pm
magnetic door contact alarm wiring 5 1380 Tue Sep 26, 2006 8:45 pm
Flourescent lights and magnetic fields 4 420 Mon Aug 01, 2005 10:02 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
