DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How the heck does my toilet work?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
funkygibbon
from United Kingdom
PostPosted: Fri Jan 26, 2007 5:42 pm Reply with quote
Hi guys,
A newbie here. Sorry, I go on a bit in this one!!!
My toilet is a really old Twyfords Unitas 310. I don't really want to replace it as it looks really nice and goes well with the original wide sink and bath that we also have.
Just before Xmas my toilet became difficult to flush, my self diagnosis was a split cistern diaphram.
I thought this would be a good opportunity to replace the whole cistern workings with a push button system. Got all the bits, and set to work on Christmas eve morning.
Everything seemed to go really well, it all fitted back together, and after an hour or so it was all put back, and the water switched back on.
Waited for the cistern to fill and pressed the button for the maiden flush. Didn't work. The water drained out of the cistern into the bowl, which then filled up to the rim and then drained away V-E-R-Y S-L-O-W-L-Y!!!!! It was just like the toilet was blocked, which it wasn't.
Tried adjusting the water level, but it seemed to make no difference whether really full or not much in. I must have done a hundred flushes, and it probably only flushed properly about half a dozen times intermitantly. Anyway, in the end after much messing about I ended up getting a new diaphram and putting the old syphon system back in which now works perfectly.
Why didn't the push button flapper system work with my old toilet. The bumph on the packaging said that it was compatible with all toilet systems.
What I did notice, and I think this is probably the key area, is that the syphon didn't just feed into the toilet bowl like a normal toilet. Just below the cistern joint there is a metal pipe, which contains what looks like a 'torpedo' facing up, with a rubber seal on the bottom end. The rubber seal bungs up a half inch hole which feeds into the top loop of the s-bend. It's really difficult to explain, but if you've ever seen one in the flesh you'll know exactly what I'm going on about. I'm guessing this is some sort of dual syphon thing that opens up the hole and feeds some water into the s-bend to trigger the syphon effect and then closes up directing the water into the bowl to flush properly.
It's all a bit unusual.
Can anyone throw any light on the workings of my toilet?
Thanks for listening!
Mike.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1459 times
PostPosted: Fri Jan 26, 2007 5:49 pm Reply with quote
You have a syphonic WC. These are very good and quiet, but your one flushes in a different way.
I don't know what you should do with it. I wouldn't swap it for a new one in your position - I don't think they're obtainable any more, and used to be very expensive.
Someone will probably know, or you could contact the manufacturer.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
What the heck have I done? 15 560 Thu Apr 26, 2012 8:48 am
Where the heck is my central heating pump?! 7 500 Wed Sep 03, 2008 10:24 am
Cast iron tiled insets How the heck do you fit them??? 2 300 Mon Apr 16, 2007 12:14 pm
Extending toilet and bathroom work ? who to call ? 3 40 Wed Jan 15, 2014 8:59 pm
how do I work out what make my shower is? 4 300 Sun Apr 20, 2008 1:21 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
