Glossy
Joined: 15 Mar 2004 Posts: 1 Location: United Kingdom
Posted: Mon Mar 15, 2004 6:23 pm |
I have a radiator that is cold a the top and hot at the bottom. I therefore believe I need to bleed the radiator. I have a Glow Worm Compact 100e combi boiler. Do I bleed the radiator with the boiler on or off?
My sister had a combi boiler at her last house and was left with no hot water (due to the boiler losing pressure) after she bled her radiators.
I'd be grateful for any advice that means I won't be having a cold shower before going to work in the morning! |
MANDATE
Joined: 06 Mar 2003 Posts: 2126 Location: Manchester, United Kingdom Thanked: 115 times
Posted: Mon Mar 15, 2004 7:27 pm |
Bleed it with boiler off.
Make a note of the pressure before you bleed it, because it will drop slightly as you bleed it.
You may have restore the pressure it the original reading using the filling loop. Make sure you have the filling loop before you start.
Also open the valve very slowly and observe the pressure increase.
I bled mine today ( 1 small radiator) and the pressure dropped from 1.3 bar to 1.2 bar and I have not bothered to restore the pressure as yet.
nickos556
Joined: 13 Feb 2005 Posts: 2 Location: United Kingdom
Posted: Sun Feb 13, 2005 10:21 pm |
Does the system need to be cold when you bleed the radiator, or is it okay to switch the bolier off and bleed the radiator while the system is still hot?
We have a combi boiler and I bled our radiators with the system on a few months ago, and we ended up with no hot water -needless to say the flatmates weren't happy.
Now my radiator needs bleeding again, dont want to make the same mistake twice.
cheers |
IanDB
Joined: 26 Nov 2003 Posts: 754 Location: Dorset, United Kingdom
Posted: Mon Feb 14, 2005 9:38 am |
| Quote: | | Does the system need to be cold when you bleed the radiator, |
No.
| Quote: | | is it okay to switch the bolier off and bleed the radiator while the system is still hot? |
Yes, but if you get a spray of water on you it will be hot!
Follow the instructions from Mandate and you should be OK. |
nickos556
Posted: Mon Feb 14, 2005 10:23 am |
Ok thanks for that...
Nick |
