DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Outside light
This topic originated from the How to page called Adding a new light and switch
Click here to return to the page called Adding a new light and switch.
  View previous topic :: View next topic
Author Message
dandeman
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 28, 2007 3:51 pm    Post Subject:
Outside light
Reply with quote Thanks
I want to install an outside light with pir. The cable will run from the light and into a cupboard in my kitchen, in this cupboard is my consumer unit can I wire up to the the unit and run the cable to the light via an fcu. This is the easiest option for me or will I have to take a feed from an existing light circuit. The light will have a 60watt bulb fitted.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Sun Jan 28, 2007 4:00 pm    Post Subject:
If you are sure you feel confident going into the consumer unit then yes what you propose will be ok, connect into the output of your lighting circuit.
Back to top
 Alert Moderators
dandeman
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 28, 2007 4:06 pm    Post Subject:
Thanks for the quick reply.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
good PIR external light sensor 4 260 Thu Jan 10, 2008 10:44 pm
new shaver / light socket 10 400 Sat Jan 12, 2008 1:41 pm
Building regulations part P (?) moving light switches 3 380 Sun Jan 13, 2008 2:01 am
Wiring 2nd PIR Sensor into Security Light 3 720 Thu Jan 10, 2008 8:11 pm
Fitting a Security/PIR light, which route is best? 3 260 Thu Jan 10, 2008 1:23 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
