DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Light switch shorting
This topic originated from the How to page called Adding a new light and switch
Click here to return to the page called Adding a new light and switch.
  View previous topic :: View next topic
Author Message
erasmo
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 28, 2007 11:57 pm    Post Subject:
Reply with quote Thanks
Hi all,
My first post and would be glad for some advice.
I have a wall light switch that controls the halogen lights in the kitchen ceiling. I tried to switch on lights recently and i heard a crackle from the switch, no lights came on and the breaker \\\'tripped\\\'. Tried again, and the switch stuck in off position. I presumed faulty switch. Wired in new switch and the same happened again? I now suspect problem with bulbs or low voltage transformers? Is there a DIY way to trouble shoot to problem? There are just 4 low voltage halogen downlighters controled by this 1 switch on a two gang plate. Other switch works fine with the counter top lighting.
Any help before i have to call out an electrician would be much appreciated!
thanks
Erasmo
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Mon Jan 29, 2007 1:11 am    Post Subject:
Sounds like a short circuit. The switches are welding shut, hence they wont move. Did you do anything at all to the circuit?
You could try opening up the light fitting and checking for wires touching where they shouldn't be. Or if the loop-in is at the switch, open that up and check for loose wires there too. First identify which type of circuit you have. There are diagrams in the WIKI and the "for reference" topic, to help identify what you're dealing with. We're here if you need any help.
Back to top
 Alert Moderators
erasmo
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 29, 2007 9:28 am    Post Subject:
hi crafty
thanks for the reply,
I've checked the inside of the switch and it all seems fine to my non expert eye but there is a bit of charing/melting on L1 connection so it seems a short somewhere?
I'll check out WIKI for reference but i may also post a picture of the switch connections for an expert opinion.
Nothing has been done to the circuit and non of the halogen bulbs seem blown?
I'll keep you posted
many thanks
erasmo
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Mon Jan 29, 2007 11:37 am    Post Subject:
I would guess the transformer is a dead short or the cable to it has been melted and shorted by the heat from a lamp.
Also a bit sus the switch welding on a 6 amp lighting short, is it on the lighting circuit or from a power circuit.
Back to top
 Alert Moderators
erasmo
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 29, 2007 11:56 am    Post Subject:
Hi bernardgreen,
i think the short is on the lighting side in the switch but i should post a picture so you guys can advise. In meantime, i'll check cables and see if i can find the transformers (is it normally a transformer per light or could there be 1 for the 4 lights?)
again, many thanks for help
Erasmo
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
shorting a switch 9 480 Tue Mar 20, 2007 2:03 pm
Shower - Electric Shorting Circuit Breaker 9 2020 Mon Mar 20, 2006 2:22 pm
Wouldn't fancy shorting this supply 8 500 Tue Feb 24, 2009 8:40 pm
Why is this shorting 2 way circuit? 3 220 Tue Jan 17, 2006 6:05 pm
Cooker shorting out electrics 5 180 Mon Aug 24, 2009 12:53 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
