DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Can a DIY'er replace a radiator valve without draining down?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
muffking
from United Kingdom
Thanked: 1 time
PostPosted: Wed Jan 31, 2007 9:35 am Reply with quote
Hands up, I've caused a problem for myself.
When changing a rad I snapped off the tip of the lockshield valve when it seized shut. I now need to replace the radiator valve preferably without draining the sealed combi system. Can it be done?
I've thought of pipe freezing, but can't find a kit and have no idea how much it costs.
I've thought of removing the valve top and replacing it very quickly?
I've also thought of fitting a push fit pipe isolator inline with the valve to give me time to change the valve, but I have no idea if any of these (or other) ideas are viable.
Ideas please, hopefully one without making to much of a mess.
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 80 times
PostPosted: Wed Jan 31, 2007 9:59 am Reply with quote
Turn all your other rads off and drain down. Rebalance and inhibit your system icon_biggrin.gif
Back to top
 Alert Moderators
uknokianut
from United Kingdom
Thanked: 1 time
PostPosted: Wed Jan 31, 2007 10:33 pm Reply with quote
Just drop the pressure in the system . You can swap the valve without draining down if you do it quickly, just have plenty of towels just incase.
Back to top
 Alert Moderators
fitz1
from United Kingdom
Thanked: 20 times
PostPosted: Wed Jan 31, 2007 11:12 pm Reply with quote
use a sealed builders bag to catch any water.
Back to top
 Alert Moderators
muffking
from United Kingdom
Thanked: 1 time
PostPosted: Thu Feb 01, 2007 9:59 am Reply with quote
Cheers guys. I took your advise and added a 23 domestic pipe freezing kit just in case. I managed to get away with only enough spillage to take up 2 sheets of kitchen roll icon_smile.gif
My only problem now is that after changing the rads I now have a rushing water type noise coming from the pipes which run down the wall from the upstairs boiler to the downstairs kitchen rad. I can only think of giving it a couple of weeks before bleeding the system again in case any air is in the pipework?
Back to top
 Alert Moderators
EliteHeat
from United Kingdom
Thanked: 2 times
PostPosted: Thu Feb 01, 2007 11:14 am Reply with quote
Why wait a couple of weeks? why not do it now?
Back to top
 Alert Moderators
muffking
from United Kingdom
Thanked: 1 time
PostPosted: Thu Feb 01, 2007 5:29 pm Reply with quote
I did, but the paperwork that came with the new rads said to bleed again after 2-3 weeks, probably in case fitting the new rad creates an airlock in the system?
Back to top
 Alert Moderators
gigz
from United Kingdom
Thanked: 560 times
PostPosted: Thu Feb 01, 2007 6:42 pm Reply with quote
That just means bleed again in a few weeks anyway, you can bleed at anytime if you think theres air in, if its topped up with inhibiter and no leaks it should be fine.
Back to top
 Alert Moderators
muffking
from United Kingdom
Thanked: 1 time
PostPosted: Thu Feb 01, 2007 9:09 pm Reply with quote
Yeah I filled the largest rad with 1/2 litre of inhibitor to be on the safe side, but I'm concerned as to what the rushing water in the pipe coild be caused by?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
No HW after draining CH system etc to replace rad valve 33 1880 Sun Jul 16, 2006 4:02 pm
Draining CH system to replace rad valves - please help! 5 120 Thu Jan 26, 2012 1:05 pm
Draining Cold Water Tank To Replace Taps 3 1280 Sat Aug 25, 2007 5:30 pm
draining twin-valve radiator 4 900 Tue Sep 11, 2007 7:56 pm
Can I change a radiator valve without draining the system ? 7 27360 Tue Jul 15, 2008 10:15 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
