Joined: 29 Jan 2007 Posts: 38 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Thu Feb 01, 2007 12:17 pm Post Subject:
!!!!!!! HELP !!!!!!!! Fitting Toilet Need some Advice
I'm fitting a toilet and wanted to know:
1/ Can I use the old soil pipe or do I need a new one as the seals maybe damaged?
2/ Do I need to add any type of sealant/ glue when reconnecting the soil pipe?
3/ I read another post which said to use "washing up liquid" to put the soil pipe back on, would this be ok? as the instructions says not to use washing up liquid as it will damage the seals.
4/ What size push fit flexible hose must I use to connect the cisten to the water inlet?
5/ I'm having to screw the cisten & bathroom sink into a plasterboard wall, what fixings do I need to get & can I buy them at Screwfix.
All the help and advice wopuld be greatly apperciated. Thanks in advance.
Joined: 18 May 2004 Posts: 19155 Location: Tennessee, United States of America Thanked: 400 times
Posted: Thu Feb 01, 2007 12:34 pm Post Subject:
why did you remove the soilpipe or do you mean the pan connector ?
no
get some silicone grease then
1/2"" x 15mm
Posted: Thu Feb 01, 2007 12:38 pm Post Subject:
Cheers KevPlumb,
Sorry I didn't make it clear. I haven't removed it but I'm in the process of changing the toilet and wanted to know if I needed to change the "waste pipe" with a new one or can I use the old one already there.
Posted: Thu Feb 01, 2007 1:00 pm Post Subject:
Well it look similar to that, although mine bends off to the left when looking straight on. Are they all a universal size because the one on my toilet (the part that goes into the waste pipe connected to the stake) looks bigger?
Joined: 24 Jul 2003 Posts: 18665 Location: London, United Kingdom Thanked: 62 times
Posted: Thu Feb 01, 2007 2:59 pm Post Subject:
Those fixings will not take the weight of the cistern or the basin, only hold it against a wall. ALmost better off with just lots of silicone.
You can get much stronger pboard fixings, but they're all only as strong as the board.
To carry weight, cut a letterbox in the pboard, fix plywood across the studs and screw to that. Tiles hide it.
If not tiling, put a noggin to fix to, between the studs, and replaster.
Oh and most soil pipes are nominal 4", but quite a lot are 3 1/2", for which you'll see fittings in the cats.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
