can anybody explain why the flow switch spindle fails to come out far enough to reach the micro-switch,i have cleaned the spindle and check the diaphram and all is ok,pump runs ok and system pressure is 1.5bar,i would be very greatful for any help,thank you,wes.
good morning,thank you for your replies,there is no air in the boiler or pump and i examined the diaphram and it seems ok ie theres no holes in it,do you still think i should change it,im really confused?
it seems as if there isnt enough pressure to push the diaphragm out but the is 1.5 bar in the system,when i half close 1 of the boiler isolation valves the spindle will make contact with the micro switch?
thanks baxpoti,i will try that,i would of thought that if the diaphagm wasnt bursted that it would be ok,what other faults can happen with a diaphragm and why would it stop the spindle from moving out far enough? ive came across this problem a good few times with this boiler have you?
thanks a million lads,thats a great help,i think the heat ex is starting to get blocked with lime,what chemical would yee recommend me to use to de-scale it,do any of yee know much about fernox ds40????
