DIYnot
Local | Network
   DIYnot > Forums
Local | Network
astra battery light power steering
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
fireman22
from United Kingdom
Thanked: 10 times
PostPosted: Sun Feb 04, 2007 10:08 am Reply with quote
Y reg astra 1.7 deisel estate
hi battery was low after not using car for a few weeks put a new battery on it but now battery ligt is on and power steering is not working could it be as simple as a fuse or a friend said it could be the alternator? any help greatly accepted thanks
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 132 times
PostPosted: Sun Feb 04, 2007 10:25 am Reply with quote
If this started to happen as soon as you fitted the new battery then you have omiited to re-connect something(are there push on connectors with the battery lead?) or you have shorted something which may well have blown a fuse. If the charging light is now showing I doubt it is the alternator
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 10 times
PostPosted: Sun Feb 04, 2007 10:31 am Reply with quote
yes but battery light being on shows its not charging, doesnt it?
Back to top
 Alert Moderators
KingboyD
from United Kingdom
Thanked: 29 times
PostPosted: Sun Feb 04, 2007 3:51 pm Reply with quote
The Alternator has failed, not enough power output = power steering shuts down. Seen it a few times and a new alternator always fixes it icon_smile.gif
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 128 times
PostPosted: Sun Feb 04, 2007 4:23 pm Reply with quote
If my memory serves me well, that cart doesn't have electric power steering.
I'd check the drive belt.
Back to top
 Alert Moderators
jonnyfishing
from United Kingdom
Thanked: 27 times
PostPosted: Sun Feb 04, 2007 7:40 pm Reply with quote
According to my info, fuse No.7 (fuse box nearest the n/s wing) in the engine bay is for the power steering.
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 128 times
PostPosted: Mon Feb 05, 2007 9:37 pm Reply with quote
I checked today. The power steering on the car is driven by the same belt that drives the alternator. It's not electric so, it can't be a blown fuse.
Back to top
 Alert Moderators
libby lou lou
from United Kingdom
Thanked: 43 times
PostPosted: Mon Feb 05, 2007 9:57 pm Reply with quote
your car is belt driven, check the fluid
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 128 times
PostPosted: Mon Feb 05, 2007 10:37 pm Reply with quote
Battery light is on too, sounds like the belt to me.
Back to top
 Alert Moderators
cjbigboy
from United Kingdom
Thanked: 1 time
PostPosted: Sat Feb 10, 2007 2:56 pm Reply with quote
Sorry people, but all Astra G's (Mk4)from late 1998 onwards have an electrically driven Hydraulic steering pump, not belt driven. Being a Y reg i.e 2001 this is the case.
Look down behind the gearbox toward the bulkhead and you will see the fluid reservoir that sits on top of the pump.
http://www.bba-reman.com/content.aspx?content=vauxhall_astra_1_8_power_steering_failure
Alternator failure will always shut down the power steering, as the pump obtains it's power directly from the alternator.
Replaced loads of these whilst at Vauxhall, including my own Astra.
CJ
Back to top
The following user says thank you to cjbigboy for this useful post:
mkh (11 Jul 2011)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
Astra MK3 power steering 3 100 Tue Oct 23, 2012 12:24 pm
Volvo V70 power steering 5 4320 Sat Apr 05, 2008 7:37 pm
Power steering 2 540 Wed Aug 02, 2006 10:30 pm
Corsa Electric Power Steering (EPS) 4 1760 Mon Apr 21, 2008 11:17 am
Renault Master power steering pump bracket 2 160 Sun Dec 05, 2010 4:39 pm
DIYnot
