kayla99
Joined: 05 Feb 2007 Posts: 9 Location: Cheshire, United Kingdom Thanked: 0 times
Posted: Tue Feb 06, 2007 12:02 am Post Subject: PUZZLED WITH COMBI SYSTEM |
Want to move a radiator by 6 inches but this means having to shorten the pipes. I beleive I'll have to drain the combi system to do this, any advice that you could give me?
Thanks |
kevplumb
Joined: 18 May 2004 Posts: 19144 Location: Tennessee, United States of America Thanked: 400 times
Posted: Tue Feb 06, 2007 12:08 am Post Subject: |
close the valves on the boiler and the auto air vent and all the rads then go and play with a drip tray
DONT open both sides at the same time (yer get wet)  __________________ a little thanks
goes a long way |
ChrisR
Joined: 24 Jul 2003 Posts: 18661 Location: London, United Kingdom Thanked: 62 times
Posted: Tue Feb 06, 2007 7:42 am Post Subject: |
Wot ee means is that if you close all the places air can get in, the water will "hang" in the pipes.
Close the rad valves, drain the rad and remove it, close things as above, clean the pipes well, cut 6" out of one pipe (drip tray) then reconnect it (the neatest would be the slim metal pushfits you can get now).
Then repeat for the other pipe. |
Paul Barker
Joined: 04 Aug 2005 Posts: 5481 Location: Yorkshire, United Kingdom Thanked: 18 times
Posted: Tue Feb 06, 2007 8:31 am Post Subject: |
But you need an oxy acetaleen blow torch, or use pushfit or compression. |
