DIYnot
Local | Network
   DIYnot > Forums
Local | Network
hotpoint DWF50 Dishwasher
This topic originated from the How to page called Dishwasher Troubleshooting
Click here to return to the page called Dishwasher Troubleshooting.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
techienot
from United Kingdom
PostPosted: Wed Feb 07, 2007 1:41 pm Reply with quote
Hi there I wonder if anyone can be of help. I have a hotpoint DWF50 dishwasher, It fills ok with water on a wash, drains away but as soon as it goes on to the rinse cycle it stops and makes a humming sort of noise and also the green eco wash cycle light starts flashing. I have checked the water coming in/out and the filters so Im at a loss. Any ideas ? icon_question.gif
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 27 times
PostPosted: Thu Feb 08, 2007 10:09 am Reply with quote
It's leaking into the base, drain the base and try again. Check for a leak.
What tablets are you using? Do you put rinse aid in the machine?
Back to top
 Alert Moderators
techienot
from United Kingdom
PostPosted: Thu Feb 08, 2007 1:15 pm Reply with quote
Hi there, thanks for your reply. I use finish dishwasher tablets and finish rinse aid. However I am confused, leaking into the base ? do you mean the base of the machine ? Theres been no water on the floor or anything to indicate a leak.
Many thanks
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 27 times
PostPosted: Thu Feb 08, 2007 1:34 pm Reply with quote
It shouldn't leak onto the floor. It's a sealed base with an anti flood device.
Your anti flood device has been activated, therefore, base is flooded.
If you're using finish 3,4 or 5 in 1 tablets and rinse aid. This would mean that you're double dosing on rinse aid, the tablets have rinse aid built into them and this is probably causing excessive foaming. This could account for the flooded base.
Drain the water out of the base of the machine. Try it through a programme without a tablet and check for leaks into the base.
You'll have to stop using tablets and use powder until the rinse aid in your machine is finished to prevent overfoaming.
Back to top
 Alert Moderators
techienot
from United Kingdom
PostPosted: Thu Feb 08, 2007 2:02 pm Reply with quote
Hi there.
Do I just manually hold the waste pipe upside down to drain it or is there somewhere at the back that I unscrew and it should drain ?
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 27 times
PostPosted: Thu Feb 08, 2007 2:57 pm Reply with quote
Power off, take off the lid and left hand panel. Sponge the water out of the base or some tubing and syphon it out.
Back to top
 Alert Moderators
techienot
from United Kingdom
PostPosted: Thu Feb 08, 2007 7:03 pm Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Hotpoint Dishwasher DWF50 Eco error flashing 3 3280 Sun Oct 16, 2005 2:55 pm
Hotpoint DWF50 dishwasher 3 1060 Sat Apr 21, 2007 8:04 pm
Hotpoint dishwasher DWF50 lights 4/6 5 40 Thu Jun 07, 2012 2:01 pm
Hotpoint DWF50 Dishwasher Tripping Breaker Switch 3 3920 Tue Jun 26, 2007 6:31 pm
Hotpoint DWF50 Dishwasher Tripping RCD 7 2780 Mon Apr 28, 2008 7:43 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
