DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
iron soil stack to earthenware socket
This topic originated from the How to page called Drainage Systems
Click here to return to the page called Drainage Systems.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
colliseum
from United Kingdom
Thanked: 0 times
PostPosted: Sat Feb 10, 2007 12:52 pm    Post Subject:
Reply with quote Thanks
I,m replacing my kitchen and after removing the old cupboards noticed that the area where the main soil stack exits the property was damp.
After closer inspection there seemed to be no obvious seal around the connection onto the earthenware socket.
I\\\'m sure the pipe should be cemented into the socket. if so what should it be sealed with.
Also the area around he pipe is damp mud. would this be the soil waste or just dampness from the ground where the waste pipe disappears
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
doitall
from United Kingdom
Thanked: 240 times
PostPosted: Sat Feb 10, 2007 1:03 pm    Post Subject:
One would wrap rope around the pipe and push it into the socket, then fill with a special cement available from builders merchants.
Neat cement will do if you get stuck, mix it into a paste, and don't play with it because it goes off quick.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Sat Feb 10, 2007 4:14 pm    Post Subject:
bit of newspaper in the gaps in the socket , then 1;1 sand cement icon_wink.gif or jetcem
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Fused spur or unswitched socket outlet? 18 740 Wed Jan 23, 2008 8:33 pm
Boiler Socket Causing trouble 3 420 Sun Sep 23, 2007 7:24 pm
Immersion heater plug socket size 3 140 Wed Nov 05, 2008 4:52 pm
new boiler powered via plug in socket ok? 15 560 Thu Nov 06, 2008 2:30 pm
gas poker socket 2 120 Tue Mar 24, 2009 6:24 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
