DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Replacing handrail (Pictures now added)
This topic originated from the How to page called A new look for existing stairs
Click here to return to the page called A new look for existing stairs.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
PaulMcG
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 11, 2007 10:59 am    Post Subject:
Reply with quote Thanks
Hiya,
We recently had to cut out the lower section of our handrail / banister on our staircase in order to get a new sofa into the living room (doh! icon_smile.gif and it's now time to replace the handrail / banister.
The only concern I have, is how it joins into the upstairs sections - as it seems to be integrated partly into the side of the landing floor upstairs, I'm guessing a picture would really help you give me some help here? icon_smile.gif
It's an open staircase, in that it has the usual railings and not boarded in etc - it's just the adjoining part upstairs seems a bit `odd`
I'm also looking to remove the undstairs cupboard (which seems to just be a wooden frame and panels over that (no brick walls) so should be quite safe to take out?
http://homepages.nildram.co.uk/~dr3amz/stairs/stairs1.jpg
http://homepages.nildram.co.uk/~dr3amz/stairs/stairs2.jpg
http://homepages.nildram.co.uk/~dr3amz/stairs/stairs3.jpg
http://homepages.nildram.co.uk/~dr3amz/stairs/stairs4.jpg
http://homepages.nildram.co.uk/~dr3amz/stairs/stairs5.jpg
http://homepages.nildram.co.uk/~dr3amz/stairs/stairs6.jpg
http://homepages.nildram.co.uk/~dr3amz/stairs/understairs1.jpg
http://homepages.nildram.co.uk/~dr3amz/stairs/understairs2.jpg
http://homepages.nildram.co.uk/~dr3amz/stairs/understairs3.jpg
The `ceiling` under the stairs is just simple boarding by the looks of it too so shouldnt be an issuing modifying.
Thanks,
Paul
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
noseall
from United Kingdom
Thanked: 73 times
PostPosted: Sun Feb 11, 2007 12:46 pm    Post Subject:
i personally think you will need to remove the spindles and handrail up to the point where it first joins the horizontal section, then replace with new stuff from there.
it's an odd set-up, as the handrail does not continue up to the top newel. this means you have to grab onto the spindles as you first descend the stairs.
Back to top
 Alert Moderators
PaulMcG
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 11, 2007 3:12 pm    Post Subject:
Yeah well my plan for that part would be maybe to make it like this (edited image) as there's no way to make it run right to the top because that would mean resizing the hallway or stairs lol icon_smile.gif
http://homepages.nildram.co.uk/~dr3amz/stairs/newedit.jpg
Any concerns on taking out the frame below that makes the cupboard? in this picture you can see the base of the banister end (whatever you call it icon_smile.gif
Although I find it hard to believe that the frame would be there for support of any kind based on the wood its made from...
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 73 times
PostPosted: Sun Feb 11, 2007 4:35 pm    Post Subject:
it appears that the head of your staircase has been fitted to a full width trimmer and i'm fairly confident you can remove all the framing below.
Back to top
 Alert Moderators
PaulMcG
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 12, 2007 8:22 am    Post Subject:
Sorry, but what exactly do you mean by `head of staircase fitted to full width trimmer` ? icon_smile.gif
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 73 times
PostPosted: Mon Feb 12, 2007 5:23 pm    Post Subject:
a trimmer is a piece or pieces of timber designed to span an opening where by sections of floor, stud wall or even roof have been omitted. these trimmers are often doubled up to handle the extra load.
the trimmer in your case is a piece of timber spanning the stair well walls, indicated by the lower ceiling in the downstairs passage leading to the bathroom. it may be built into the walls, in your case the downstairs bathroom and lounge walls.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Fantasy Idea..New Set of Stairs! [Dissection Added] 13 880 Sat Nov 03, 2007 7:13 pm
how to replace/fix damaged joist in bathroom? added pic 2 260 Mon Mar 23, 2009 3:14 pm
Help replacing Newel Posts - pictures.. 3 1940 Wed Feb 13, 2008 10:48 pm
Cement Or 'Proper' Tile Adhesive For Vertical Tiles?Pictures 23 1500 Mon Apr 16, 2007 11:21 pm
loft conversion pictures inc 11 700 Thu Jul 03, 2008 8:20 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
